SOHC y8 and y7 questions
Are the 2 different generation SOHC Vtec bottom ends identical....
If i had the older head with the newer bottm end?
thanks
thanks
Re: SOHC y8 and y7 questions (hondaspeder)
The Y8 is a SOHC VTEC motor and the Y7 is a SOHC nonVTEC motor. Both are from the same generation cars: 1996-00. I'm not sure what you're trying to do, maybe you're confusing the 92-95 D16Z6 (SOHC VTEC) with the 96-00 D16Y7?
mattt
12-15-2002 01:54 AM
