B18C1 in CRX
B18C1 in CRX
Hello, I've got the engine in the car, done all the wiring (I'd sugest purchasing the kit to anyone, I didn't hasports.com has one). Does anyone know the correct way to do the vacuum lines on this conversion? I've got it where it runs, but not smooth. I'm prety sure its due to the vacuum lines.
Thanks
-brad
http://www.draglinepro.com
Thanks
-brad
Re: B18C1 in CRX (FOrSfEd)
All you really need to hook up vacuum wise to get the car running good is the Map sensor. If your gsr motor has the gsr tbody then the map is already plumbed in just make sure you plug in the right plug and don't mix up the map and TPS plugs.
I've probably done 20 or so swaps in ef's and all I ever hook up is the MAP and never had any idle problems. I also live in an area with no emissions testing.
eightvalver
08-23-2004 08:41 PM
Ri5e
03-27-2003 06:18 PM
