repin plugs?
Old Mar 4, 2005 | 11:49 AM
spooned out's Avatar
Default repin plugs?
search function is down.. i searched before but didnt come up with anything.....
For the distributor plugs/wires is it possible to repin them instead of cutting them and match? I'm using obd1 plugs with obd2 dizzy and alternator.... i found the wiring info but would like to knoe if i can depin and repin for right location instead of cutting...... ( if its possible what tools is needed and is it worth the hassel?)
thanks...
Old Mar 4, 2005 | 02:44 PM
crxtreme89h's Avatar
Default Re: repin plugs? (spooned out)
It's probably worth the hassle for the clean look, however you should cover those wires with loom. If you do this it is pointless in re-pinning cause it will be covered up anyway. I would just cut, strip, solder, and tape.
If you decide to re-pin then use a paper clip or a pin tool. I used a paper clip and my Craftsman Pin tool set.
Old Mar 4, 2005 | 03:46 PM
eda6's Avatar
Get a pair of needlenose pliers and pull out the plastic piece (usually white or blue)inside the plug. It's possible to remove the male pins using only your finger, just push the pin towards the tab and pull the wire out. For the female pins get a pocket screwdriver and simply push the pin towards the tab and remove the wire.
depinning>soldering
if you decide to cut and solder, use heat shrink tubing instead of tape.
Old Mar 4, 2005 | 06:07 PM
Default Re: (eda6)
i dont really like hacking up wires when i don't need too, it looks like i'ma try the depining and repining as my first option see how that works out..... thanks for the info
drfraser
Jan 6, 2013 08:57 AM
yek99
Oct 14, 2012 12:04 PM
r3000
Feb 14, 2005 01:46 PM
jDMJeRk
Jul 23, 2004 12:38 PM
HX_Guy
Sep 13, 2001 02:43 PM
