h22 swap done but not starting HELP
well lets start with the basics
95 accord EX with JDM H22 swap, jdm p13 ecu
go to start it up and its not starting, gettin spark and fuel still no start up
just the header is on and the ecu is good, it does like make a backfirin noise but thats it
Re: h22 swap done but not starting HELP (xv53)
gonna check the timing on it and i messed with the firing order a few times, is the firing order same for the accord cause thats the one i used, also im gonna check the timing tomorrow
Re: h22 swap done but not starting HELP (95accordh22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95accordh22a »</TD></TR><TR><TD CLASS="quote">gonna check the timing on it and i messed with the firing order a few times, is the firing order same for the accord cause thats the one i used, also im gonna check the timing tomorrow</TD></TR></TABLE>
top left is #3
top right is 4
bottom left is 1
bottom right is 2
On the engine, #1 is on drivers side and #4 is passenger side.
try that, if not then timing. Same thing happened in my swap, and it was timing for me. Back fires through an open header are loud as hell in a garage though. The first time mine backfired, the neighbors 4 houses down thought we were shooting a 12 guage in the backyard. it was funny.
top left is #3
top right is 4
bottom left is 1
bottom right is 2
Re: h22 swap done but not starting HELP (93delslo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo »</TD></TR><TR><TD CLASS="quote">
try that, if not then timing. Same thing happened in my swap, and it was timing for me. Back fires through an open header are loud as hell in a garage though. The first time mine backfired, the neighbors 4 houses down thought we were shooting a 12 guage in the backyard. it was funny.</TD></TR></TABLE>
the back fires were the best part especially since it was night time, funny and loud as hell... also i just got it workin, it was th efiring order, my book made it seem that cylinder one was the top one on the dizzy, but you helped alot , thanks
The OEMobile
08-17-2003 05:05 PM
