EK swap questions/confirmations
I want to put a 99-00 Si motor in my 98 DX Hatchback. I searched and found a lot of info... but a lot of it is confusing and possibly wrong. So here's my questions:
1. Did the 99-00 si have a b16a2 or a3?
2. Are there ones that are obd1? (I need obd2)
3. Is there a difference between jdm a2's/a3's and usdm ones?
4. I know I need the wire harness, ecu, a rear mount from a Si or CRV; Do I need anything else (axles, shift linkage) or can I used my own from my car?
5. Is there any wireing switches if I use a 99-00 Si motor? I've seen that people have to do it when the switch OBD's but I'm not sure that will apply to me since both motors will be OBD2?
6. This one sounds stupid but is there anything else I'm missing?
Thanks for you help.
cool guy name
Re: EK swap questions/confirmations (Dirty Dee)
1 99-00 SI was a2
2 obd2b
3 no clue
4 you are gonna need axles shift linkage, 96-98 ex wiring harness, and some other things that someone else will chime in with
5 Dont understand the ?, there is a obd2a and a obd2b
6 yes
no prob,
Jim
2 obd2b
3 no clue
6 yes
no prob,
Jim
Re: EK swap questions/confirmations (walker111)
yeah i was cofussed about what a b16a2 came out of so if i get a b16a2 for my 97 dx i don't have to get a wire harness to make it obd1 to obd2 i was told the b16a2 is from a delsol and its obd1 or soemthing like that so i had to get a wire harness from skunk2 to make it run in my hatch
