STR H22 intake mani in EG?
does anyone have an str intake manifold on an h22 in a 92-95 civic? how does it fit?pics?
Modified by bjfisher at 12:00 PM 3/11/2005
Re: (bjfisher)
Why not just go with a Golden Eagle manifold? It yielded some pretty nice results on my friend's H22A EG, and fit nicely. I wonder what the difference would be in power...if any!
Well, Id say go with golden eagle, they seem to have the best results. I know the venom mani takes work to fit and I wouldnt get something like that from ac. The skunk mani might be ok too, especially if you want to kep low end performance a little better than the more race orientated manis
NXLude - this car IS race oriented, and skunk2 sucks for FI
h22 civic - you got pics and why would you use ge over str?they appear to be the same to me
Re: (bjfisher)
i said g/e cause thats what i have on my car know with no probs so i coulsd def sayy 100% it works well with no probs as far as str i used to deal with their stuff and just didnt like it thats just my 2cents but you r rite they do look identical
Modified by h22 civic at 10:46 PM 3/14/2005
Modified by h22 civic at 10:52 PM 3/14/2005
Modified by h22 civic at 10:54 PM 3/14/2005
Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">i said g/e cause thats what i have on my car know with no probs so i coulsd def sayy 100% it works well with no probs as far as str i used to deal with their stuff and just didnt like it thats just my 2cents but you r rite they do look identical
What mount kit was used in that car?
Re: (h22 civic)
i for one see nothing wrong with str....because that is what i have....i tried dealing with ge...but once they get your money.....they take there time getting you your parts...hell they were afraid to tackle a project i wanted them to do...so i did it my self.the runners on the str manifold are huge,don't know about the ge.....but i do know depending on what brake master cylinder you are using you will have to re route plain and simple....it will be self explainatory..
Re: (bjfisher)
yes i have had this in a civic hatch.92-95 and 96-00...depending on what side of your brake master cylinder your lines come out of ...will depend if you need to reroute...either way...this doesn't take but 3- mins. to and hr.next is your cold air idle valve...you can just make a plate or get a throttle body that does not have a cold air idle valve.the reason you have to do this is ,because the str manifold sets really low,and will barely touch the back bracket that connects the tranny to the cross member.
just pm me if you have any more questions
Re: (1700anddroping)
does the GE manifold have the same things?do you think itd be easier or just the same?i know you said its not hard, im jus reviewing everything, thanks for the help!
Re: (bjfisher)
yes ge has the same things...but do know how fitment is....i personally will not buy or use anything that has to do w/ GOLDEN EAGLE?????? IF YOUR NOT A HEAVY HITTER WHO CAN GET THERE NAME OUT THERE......they don't want to deal w/you....do a search on them that will tell you.
Re: (h22 civic)
Is your car lowered? If so, by how much? What axle combo are you using? Does the g/e manifold come with instructions for the h22 civic install?
