which ecu to use for a h22a swap p28 or p72
Old 03-11-2005, 07:26 PM
kholmes's Avatar
Default which ecu to use for a h22a swap p28 or p72
which is the best to use on a 92 h22a in a 98 hb?
Old 03-11-2005, 07:52 PM
Maintenance's Avatar
Default Re: which ecu to use for a h22a swap p28 or p72 (kholmes)
Either ecu will work for your motor. As long its running a h22 program or dyno tune program. There isnt really any difference between the ecu except the p72 has the iab. It depends if you hooked up your iabs on your h22a. Some ppl have them hooked up and others dont. If you plan on using your iabs then going with the p72 would be a good choice. Also with p28 you can have iabs also function too if you're good with soldering, you can components to make it work. Go on pgfmi.org. Thats a good place to start if you want learn more about ecu and such. I ran both p72 and p28 on my h22 street tuned with my wideband using uberdata. You can look into chrome, hondata, or neptune also.
Old 03-11-2005, 07:56 PM
C M S's Avatar
I prefer the P28. Its what I use with a jdmshit h22 program...
Old 03-11-2005, 08:00 PM
kholmes's Avatar
Default Re: which ecu to use for a h22a swap p28 or p72 (1SICJDM)
thanx guys, finally some good info
Old 03-12-2005, 06:15 AM
Turbogixxer's Avatar
Default Re: which ecu to use for a h22a swap p28 or p72 (Maintenance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maintenance &raquo;</TD></TR><TR><TD CLASS="quote"> There isnt really any difference between the ecu except the p72 has the iab. </TD></TR></TABLE>
And P72 has a knock board for the knock sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote">Its what I use with a jdmshit h22 program...</TD></TR></TABLE>
The jdmshit is a pretty good program, the partial throttle tuning could be better.
Old 03-12-2005, 06:23 AM
Default Re: which ecu to use for a h22a swap p28 or p72 (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">And P72 has a knock board for the knock sensor.</TD></TR></TABLE>
thanks forgot about that
732xghost
07-26-2007 03:03 PM
hqr180
02-24-2005 06:21 AM
O RLY
10-05-2004 10:42 PM
O RLY
10-05-2004 08:01 AM
1.8T_EG
05-06-2003 09:20 AM
Quick Reply: which ecu to use for a h22a swap p28 or p72
