Help 2000 si w/01 b18c5 swap Cal Smog
Hey All
Another noobie question
The motor in my SI is tired.. I am getting a b18c5 lower end for it ( Just had the Head Done) I need to make it CA smog legal.. I am getting a P73 ECU, But after searching the threads.. It looks like I will have a problem with the immobilizer. Is there an adapter that will disable the immobilizer so it wont throw a CEL code?? Do I need it to stay ODB2B?? Can someone list or provide a link of parts and steps I need to make this happen as painless as possible
Thanks in advance
Thanks in advance
Re: Help 2000 si w/01 b18c5 swap Cal Smog (royceman)
what header are you using if you dont mind me asking? im wanting this swap also, but i want to use OEM header so that I will pass the REF.
BRIANxJDM
35
05-11-2013 09:49 PM
Achenar
08-06-2004 08:04 PM
