Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed?
ok i'm about to do a swap but i've searched and some sites say i only need the rear 99-00 si mount and other sites say i need a list of mounts..
ie:Rear Tranny mount from the 99-00 Si: 50827-S04-N10
Driver side mount bracket from the 99-00 Si: 11910-P30-000
96 del Sol AC bracket: 38930-P54-000
can someone tell me exactly what i need?
thnx
thnx
Re: Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed? (ANGELIQUE)
It might be easier to go to hasport.com and buy the mount kit they have for your car and motor. theyre hard core but expensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ANGELIQUE »</TD></TR><TR><TD CLASS="quote">ok i'm about to do a swap but i've searched and some sites say i only need the rear 99-00 si mount and other sites say i need a list of mounts..
thnx
this should help: https://honda-tech.com/zerothread?id=856396 even though it's for a B18C1 which is basically the same swap.
thnx
Re: Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed? (sleeperciv)
its different mounts in a eg...i believe eg's need integra mounts...
still need to know..nebdoy know?
thnx
thnx
You need the rear tranny bracket and A/C bracket for sure. I'm not sure about the driver side bracket though.
Re: Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed? (EVIL Hx Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">You need the rear tranny bracket and A/C bracket for sure. I'm not sure about the driver side bracket though.</TD></TR></TABLE>
Correct, you need the 3rd gen driver side bracket(can reuse the d/s rubber mount) and the tranny front bracket mount(can reuse the rubber mount from the civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv »</TD></TR><TR><TD CLASS="quote">
Correct, you need the 3rd gen driver side bracket(can reuse the d/s rubber mount) and the tranny front bracket mount(can reuse the rubber mount from the civic)</TD></TR></TABLE>
3rd gen driver side? can anybody confirm this?
look at my first post, has a link that B18C5-EH2 aka Tom the moderator has picture that shows you.
that link is a b16a swap into a EG not a EK...i know you need 3rd gen integera mounts when swaping into a EG...
Here you go.
- 99-00 Si Rear Tranny Bracket
- 99-00 Si or Delsol VTEC A/C Bracket
- 99-00 Si Driver Side Bracket (piece that attaches to the motor, you can reuse your old studs.
I didnt confirm it till today cuz I didnt have the bracket in hand yet. The B16A bracket wont fit your 96-00 Civic (Wont line up with the actual mount), and the D Series Bracket wont fit the B16A (cant bolt it to the motor, different pattern).
So you need to replace the driver side mount bracket on the B16A to a 99-00 Si Driver Side upper mount bracket to make it work (bolts to the motor, and lines up with the mount).
About the front tranny bracket, you need the one for whatever tranny you're using (GSR tranny-GSR front tranny mount), (B16A Tranny, B16A front tranny mount).
