95 GSR CORRECT SPARKPLUG GAP?
Old Mar 9, 2005 | 09:57 PM
Spins's Avatar
Default 95 GSR CORRECT SPARKPLUG GAP?
Just like title states. I have a gsr swap in my 95 hatch.
Old Mar 9, 2005 | 11:39 PM
B18C1 Civic EG's Avatar
Default Re: 95 GSR CORRECT SPARKPLUG GAP? (Spins)
umm.. 0.051" or 1.3mm
Old Mar 10, 2005 | 01:23 PM
Spins's Avatar
Default Re: 95 GSR CORRECT SPARKPLUG GAP? (B18C1 Civic EG)
thanks
Old Mar 11, 2005 | 02:20 PM
xracer1966's Avatar
I found .044 on a honda dealer site. i think it was Majestic or something
Old Mar 11, 2005 | 03:51 PM
Spins's Avatar
Default Re: 95 GSR CORRECT SPARKPLUG GAP? (xracer1966)
I picked some new plugs NGK BKR6E-11 the stock plugs out the engine where
BKR6E-N11. Would these be fine? Whats the difference? The stock plugs pulled of the engine had the following gaps. .048, .044, .048, .044. I believe these are the originial ones. Now all the new plugs came gapped at .040. I let the gap alone and installed. Car seems to run fine. If I have the gap to small what will the result be? To small a spark and possible not burning all the fuel?
Old Mar 11, 2005 | 08:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spins &raquo;</TD></TR><TR><TD CLASS="quote"> I picked some new plugs NGK BKR6E-11 the stock plugs out the engine where
BKR6E-N11. Would these be fine? Whats the difference? The stock plugs pulled of the engine had the following gaps. .048, .044, .048, .044. I believe these are the originial ones. Now all the new plugs came gapped at .040. I let the gap alone and installed. Car seems to run fine. If I have the gap to small what will the result be? To small a spark and possible not burning all the fuel?</TD></TR></TABLE>
ahh.. so you went with the cheap ones? i do belive that the gsr come oem with the NGK-R, part number IFR6E-11. they come pre-gapped to 0.051~0.052. the ones that you have, BKR6E-11, will also work for your car, they are just the standard NGK plugs, not the iridiums, although, if they were for the right application (95 gsr) they should have also been gapped to 0.051~0.052 as well. you can use the ones that you bought, just take them out and re-gap them. the 0.04 gap that they are at now may cause a smaller spark, like you said, not burning all the fuel and your engine may run a little rich. may cause the spark plugs to wear out prematurely. even though it is not off by much, one thing that i learned owning a honda is that it is better to have some thing "perfect" rather than just "close to perfect". i hope this helps you.
Old Mar 11, 2005 | 08:56 PM
Spins's Avatar
Actually the engine has a sticker on accessory belt side which has the plug type listed. The plugs pulled from the engine match the sticker. I'll regap them tomorrow. Thanks for the info.
Old Mar 12, 2005 | 04:48 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xracer1966 &raquo;</TD></TR><TR><TD CLASS="quote">I found .044 on a honda dealer site. i think it was Majestic or something</TD></TR></TABLE> Use NGK Copper plugs (BKR6E-11)
rockenuptown
Jun 26, 2007 02:48 PM
civicracingteam
Feb 17, 2005 03:41 AM
Rah Rah
Sep 15, 2004 02:01 PM
dc2lun
Jan 13, 2004 01:41 PM
itr817
Jul 26, 2003 06:10 PM
