gsr swap into eg rear mount bracket
i'm swapping in a 1994 gsr swap into a 1994 si. I have the 94 si rear middle rubber mount with energy motor moumt inserts and i have a 1999 b16a2 rear mount bracket.
I was told that i needed a gsr rear mount bracket, can i just use the 1999 b16a2 bracket??? will it fit right????????
Modified by bboylito at 10:57 AM 3/15/2005
Re: gsr swap into eg rear mount bracket (bboylito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote"> i'm swapping in a 1994 gsr swap into a 1994 si. I have the 94 si rear middle rubber mount with energy motor moumt inserts and i have a 1999 b16a2 rear mount bracket.
Nope. The 99 Si one is shorter. You need the one off the 94+ Integra.
i'm about to trade someone my si bracket for their gsr bracket
HOW CAN I TELL THE DIFFERENCE?? like how do i know whether or not its an h22, d series, b series etc...
thanks for the reply
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboylito »</TD></TR><TR><TD CLASS="quote">i'm about to trade someone my si bracket for their gsr bracket
thanks for the reply</TD></TR></TABLE>
Set the two mounts side by side and you WILL see the difference between the two. The Si is "shorter". Other then that, they look the same.
sanegb16
09-05-2007 01:41 PM
