Need help!! Just can't do it.
Old Mar 7, 2005 | 07:52 AM
SixguN's Avatar
Default Need help!! Just can't do it.
OK, here's my prob. I got 96 ex with h22a4. I am using my ex wiring harness. It sounded and looked simple at first cause the p13 ecu plugged right in to my stock ex harness(OBD2). Also My civic harness plugs right into the injectors. So thats a plus. Now I have no matching plugs for the distributor. And there is a connector that is located between the injector clips on the harness that doesnt match up with the motor.
If anyone has put a h22a4 into a 96-00 civic, or know's how to. I need your help. I have searched and tried for hours tryin to figure this out. It's driving me nuts!!!
Old Mar 7, 2005 | 08:00 AM
Ministry's Avatar
Default Re: Need help!! Just can't do it. (Sixgundone)
you lost me. a p13 (OBDI) plugged right in to your OBDII harness???? did you forget to mention your conversion harness or what?
were 96 civics using the OBDI plug style even though they were OBDII??
am I going crazy?
Old Mar 7, 2005 | 08:07 AM
SixguN's Avatar
Default Re: Need help!! Just can't do it. (dreamer)
sry. p5p. The h22a4 ecu plugged right into my civic ex harness.
Old Mar 7, 2005 | 08:11 AM
Ministry's Avatar
are you aware that 98+ p5p ecu's were equipped with an immobilizer?
EDIT: maybe 97's too, I'm not sure
Old Mar 7, 2005 | 08:15 AM
SixguN's Avatar
On my head it says it is a 97.
Old Mar 7, 2005 | 08:16 AM
SixguN's Avatar
Any links or something?
Old Mar 7, 2005 | 08:20 AM
Ministry's Avatar
so let's say the motor is 97. how does that tell you anything about the ecu?
honestly, I would ditch the p5p and get a p13. I think it would save you some headache. conversion harnesses are cheap these days if you don't feel like doing it yourself.
Old Mar 7, 2005 | 08:27 AM
SixguN's Avatar
My ecu says p5p.
VtecHusker
Feb 26, 2013 10:15 AM
bcook0218
Feb 2, 2012 09:19 PM
turboed4life
14
Mar 27, 2004 07:40 AM
not so civic
Aug 22, 2002 01:03 PM
