Question for h22-EG owners
Hope someone can answer this question quick....but im doing a obd1 h22a1 into a 93 dx for a friend......what harness can i use or modify since finding a h22 harness is a pain in the *** to find! 300+ for the hasport modified harness is too much for him to pay right now. can i use h23a1 harness and redo the pins and add wires for vtec? can i use 94-95 accord EX harness? are any of the plugs different if i use accord one? Hope someone can help and suggest some alternatives to the h22 harness.
Re: Question for h22-EG owners (tphan4)
my friend modified the accord one but i think its missing some sensor plugs and hsi vtec doesnt work, so he is screwed, id just save up and do it right hte first time
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">you modify the stock civic harness to make it fit the car best.</TD></TR></TABLE>
plus i think the cx is already pre-wired.......just run wire from your vtec solinoid and oil pressure switch,to the strut tower,for which pin...but i will try to find wiring diagram for you.depending on which ecu you are using.depends on whether you will need to add additional wires.
Re: (1700anddroping)
Use your stock harness and lengthen/add wires were needed.
Check out this thread...https://honda-tech.com/zerothread?id=650329
