Throttle cable unhooked from gas pedal
This is an h22 in a '97 civic EX. The cable has come undone from the pedal and I can't figure out how to tighten it at all. I am in need of the car right now so time is precious.
Re: Throttle cable unhooked from gas pedal (uncle)
see if you can put it back on the gas while it is attatched to the throttle body. if that does not work, then see if u can fab a bracket to put more tension on the cable after you hook it to the pedal and tb, to keep it from comming loose again.
Mike Antonetz
Transmission & Drivetrain
06-03-2019 10:10 PM
B2FiNiTY
11
12-02-2003 01:37 PM
