Questions about B20 Swap setup, Parts etc..
I'm running a stock b20b bottom end with a gsr head w/ stock gsr cams. I'm going to be running an obd2-obd1 conversion harness. I need some suggestions and some help. This is in a 96' Hatch btw. 1st off, can I reuse my distributor off the single cam? Can I use the stock b20b injectors? And can the sohc alternator be used as well?
The only parts I need now is a tranny with clutch/flywheel, and the motor mounts. I have the shift linkage and everything else. Sound like i'm missin anything?
Spec R
07-29-2005 09:07 PM
JMod
03-10-2005 06:03 PM
