Anyone throw a cel code 23 (knock sensor) on a p72? What was the reason?
Old Mar 10, 2005 | 04:02 PM
kholmes's Avatar
Default Anyone throw a cel code 23 (knock sensor) on a p72? What was the reason?
Ive got a jdm h22a in a 98 hb and im getting the knock sensor code and vtec isnt kicking in. I figured thevtec want going on cause the knock sensor code was in effect. Did anyone experience this and what was the problem? Thanx
Old Mar 10, 2005 | 06:26 PM
Turbogixxer's Avatar
Default Re: Anyone throw a cel code 23 (knock sensor) on a p72? What was the reason? (kholmes)
Did you wire up wire sensor? P72s have knock boards.
Old Mar 10, 2005 | 07:32 PM
kholmes's Avatar
Default Re: Anyone throw a cel code 23 (turbogixxer)
hmm, not sure what you mean. Heres the deal, I bought the swap ready for my hb. I got a chipped p28 with it but turned out to be te wrong ecu for this motor (it was chipped for a gsr). But the vtec would kick in at 6700 rpm and I didnt get any codes. Then I traded for a obd1 p13 and it ran to rich so I traded for a p72 that I have now and it runs pretty good. I dont hear any knocking but feels like it kinda bougs sometimes and getting code 23 and no vtec.
Old Mar 10, 2005 | 07:55 PM
95civicH22a's Avatar
Default Re: Anyone throw a cel code 23 (kholmes)
i have an jdm h22a and for the last year i've run a stock p28, i bought a chipped p13 but it just ran too rich and the vtec was too high, no rev limiter. I like the p28 better. next week i'm installing a wideband O2 and vafc. then we'll see whats really up....
Old Mar 11, 2005 | 10:42 AM
kholmes's Avatar
Default Re: Anyone throw a cel code 23 (95civicH22a)
I thought the stock p28 would hurt the h22a?
I tried checking the wiring to the knock sensor with a test light and im not getting any power with the car on at all. Would that mean anything or is the test light useless on that wire?
Old Mar 11, 2005 | 12:39 PM
darkblue1998ls's Avatar
Did you check the flux capacitor?
Old Mar 11, 2005 | 07:30 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicH22a &raquo;</TD></TR><TR><TD CLASS="quote">i have an jdm h22a and for the last year i've run a stock p28, i bought a chipped p13 but it just ran too rich and the vtec was too high, no rev limiter. I like the p28 better. next week i'm installing a wideband O2 and vafc. then we'll see whats really up....</TD></TR></TABLE>
You run a stock P28 on an H22 with no problems? You smoking crack? You don't think that maybe the fuel tables for a 1.6 might be just a TOUCH too lean for a 2.2l? Jesus...
Old Mar 11, 2005 | 07:31 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes &raquo;</TD></TR><TR><TD CLASS="quote">I thought the stock p28 would hurt the h22a?
I tried checking the wiring to the knock sensor with a test light and im not getting any power with the car on at all. Would that mean anything or is the test light useless on that wire? </TD></TR></TABLE>
What? No. Is the knock sensor hooked up? Is it pinned correctly? Do you get the code right away, or does it take a while to come on?
Old Mar 11, 2005 | 07:38 PM
kholmes's Avatar
Default Re: Anyone throw a cel code 23 (Hybrid93Eg)
Chipped p28, relax!
I tried jumping the knock sensor tonight and it still lit up. Im pretty sure I have the right wire but not positive. The code takes a moment to come on. When it gets warmed up or pretty much right away when its already warm. Would it be actual knocking or does the code just mean the sensor is bad?
Old Mar 11, 2005 | 08:03 PM
Maintenance's Avatar
First thing I would do is make sure the knock sensor wired is actually and properly hooked up the to the right ecu location. Even though the swap is prepped for your hb, you still need to run the wire from knock sensor to the ecu. After you checked that out, and everything is properly wired, then I would check with the knock sensor itself. Remove it and try it with a different ks.
Old Mar 11, 2005 | 08:30 PM
kholmes's Avatar
Default Re: Anyone throw a cel code 23 (Maintenance)
cool, so is a stock p72 cool to use?
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
HatchWarehouse
Apr 5, 2006 08:17 PM
matman4444
Jul 30, 2004 09:30 AM
WreckedTeggie
Apr 19, 2004 07:32 AM
gaydm.accord
Mar 8, 2004 03:53 PM
