gsr crankshaft into a 1st gen b16 block
my under drive pulley broke off a piece of my crankshaft and since i need to replace my crankshaft to be able to put a pully on it i was wondering if i could use a gsr crank in a 1st gen b16 block. thanks in advance
tom
tom
Re: gsr crankshaft into a 1st gen b16 block (89crxhf)
Gsr crank is not a direct bolt in,It would require custom rods or pistons.The crank has a longer stroke and narrower rod journals.
Glenn
Glenn
