Swap Question.
Old Mar 10, 2005 | 12:57 AM
chinegro's Avatar
Default Swap Question.
Does anyone know where i could go to get step by step instruction to do a B18b swap obd2 into a obd2 civic dx.
Planning to tey it my self and i need step by step insructions.
Please this is my first time using honda-techa nd i really don't know how to search for stuff on this yet so just help me out please.
Old Mar 10, 2005 | 01:08 AM
rovigian's Avatar
Default Re: Swap Question. (chinegro)
I did my first swap with the help of this
http://www.c-speedracing.com/h...p.php
My swap was a OBD1 GSR into an OBD1 LS, so it wasn't the same as the writeup, but it will work fine.
OBD2 means nothing, this writeup will be your godsend for a first swap.
Old Mar 10, 2005 | 03:28 AM
chinegro's Avatar
Default Re: Swap Question. (rovigian)
Thanks Dude, that looks as if it is going to work, by the way did you run into any problems while doing it. I am going to try this by this month and see how it comes out how long did it take you to do it.
Thanks alot again.
Old Mar 10, 2005 | 04:34 AM
kaoss_11's Avatar
B A N N E D
Honestly thats an easy swap. Drop it in and plug and play
Old Mar 11, 2005 | 02:28 PM
xracer1966's Avatar
This is the site I got all of my info from. They have a lot of info and tech you little tricks to use on the way. I wouldn't buy anything fromthem, but the info was very good.
http://tech.hybridgarage.com/t....html
Old Mar 11, 2005 | 07:36 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">Honestly thats an easy swap. Drop it in and plug and play</TD></TR></TABLE>NO IT IS NOT PLUG AND PLAY!!!!! YOU HAVE TO CHANGE OUT SOME OF THE PLUGS AND EXTEND SOME OF THE SENSOR WIRES (both O2 sensors, IAT Valve, crank sensor, etc...)
elmalouno
Jul 3, 2011 09:00 AM
miamijdmcoupe524
Sep 17, 2010 10:18 AM
meagainsttheworld
Jul 28, 2006 09:31 AM
boosted-delslow
Mar 10, 2004 06:36 AM
EH3_Si
Jul 8, 2003 04:03 AM
