GSR swap a/c question
I searched and found a few things. I found one saying that I could use my stock D series a/c comp if I got a different mounting bracket? Anybody know about this and where I could get one. The other thing I read was that I needed to get the a/c comp and bracket off of the gsr. Can somebody please set me straight on this.
Re: GSR swap a/c question (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">Use your stock compressor.
You can use the following brackets:
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
The crv bracket is half the price of the del sol bracket.</TD></TR></TABLE>
Same thing though?
Same thing though?
Would it be easier just to do that and could I use all the bolts that are on mine now for those mounts? Also where do you think the best place would be to find them.
Sorry for all the questions, new to swaps.
Re: GSR swap a/c question (civic_speed99)
i got all of my a/c from a del sol- compressor and lines. the bracket is from a del sol as well. i don't remember which tensioner pulley i used, i just remember it was a pita finding one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">
Same thing though?</TD></TR></TABLE>
Not exactly the same part. But it works fine. The CRV used a b series motor with the same compressor as the civic. The bracket looks a little different than the P54 but everything mounts the same as the P54.
Has anybody actually used this one?</TD></TR></TABLE>
I have and there are plenty of other people on on H-T that have used it. Just search P7J. Something should pop up. All the holes match up perfectly. You will not have a problem with the crv bracket.
ej8slim
09-10-2005 04:56 PM
