distributor for dpfi to mpfi conversion
Old Mar 11, 2005 | 10:33 AM
esteen2's Avatar
Default distributor for dpfi to mpfi conversion
which distributor can I use for my conversion, can i use the stock one off of the d15 ? I am installing a d16a6 with a d16y8 manifold, RC injectors, ported head,+ web cam. I also need an ECU which one is the best to use (I will most likely have it chipped). I have si wiring harness to use. THANKS !
Old Mar 13, 2005 | 07:27 PM
VTECVillain's Avatar
Default Re: distributor for dpfi to mpfi conversion (S2R Honda)
You will need to use a 1988-91 Civic/CRX Si or CRX HF distributor - those are the only ones that can be used with an OBD0 D series MPFI conversion.
cgross
Dec 23, 2012 12:08 AM
civic minime
Jul 31, 2006 10:28 AM
ID_ten_T
Jan 15, 2004 04:17 AM
