Wiring issures with 95 gsr swap into a 99 ex
Is there any way to on obd1 engine obd2 so that it will pass emissions, suck as changing out sensors from one to the other. I was origionally just going to use the conversion harness, but will that pass?
Re: Wiring issures with 95 gsr swap into a 99 ex (civic_speed99)
the harness will not help pass emissions on an obd2 car. all they do is plug up the test and see if u have any check engine lights... u would need to run the crank angle sensor(obd2 oil pump) and another o2 sensor and just run the stock EX ecu during the test. i know im forgeting something else......ill remember the rest later.
I was going to run a gsr ecu, I know I could use my wire harness and get an adapter but then I wouldn't even link up to search for codes. I was just wondering if I could convert those things like you said and run the obd2 ecu.
TIPSY-99civic
16
07-11-2012 05:57 PM
williebrenn
08-13-2008 03:44 PM
iheartmyej8
02-11-2007 06:30 PM
