89 crx engine harness
Old Dec 2, 2011 | 08:42 AM
My89crx's Avatar
Default 89 crx engine harness
Im putting a b18 in my 89 si crx. Will my stock engine harness work?
Can I still use the stock pm6 ecu ?
Thanks for your help
Old Dec 2, 2011 | 08:52 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 89 crx engine harness
What does this have to do with Engine Management and Tuning?
Old Dec 2, 2011 | 06:05 PM
mtber's Avatar
https://honda-tech.com/forums/forumdisplay.php?f=18
Old Dec 3, 2011 | 01:38 AM
7rrivera7's Avatar
Yes, your engine harness will work and although the PM6 will start and run the B18 as long as it has an OBD0 ignition, you should get it chipped and tuned on Turboedit as there is quite a bit of difference in the fuel and timing maps. The best solution is to convert the CRX to OBD1 using a 92-95 ignition, a OBD0 to OBD1 ECU conversion harness, an OBD0 to OBD1 ignition conversion harness (if you don't know how to re-pin the connectors), and a chipped P28 ECU. It's also possible some of the sensors will need connector swaps depending on the year of the B18.
Last edited by It Wasn't Me; Dec 4, 2011 at 12:52 PM. Reason: Unauthorized solicitation
stealthmodeSI
19
Feb 20, 2020 04:06 PM
komet 163
Oct 18, 2015 04:43 PM
jarhead90crx
12
Aug 5, 2011 07:06 AM
fatCRXguy
Feb 5, 2009 07:49 PM
ph3ar
12
Oct 30, 2007 09:17 PM
