Which A/C Compressor for H2B q/ QSD kit
Old 01-27-2012, 07:25 AM
Ek Forever y0!
Libertariat's Avatar
Default Which A/C Compressor for H2B q/ QSD kit
So I've been talking back and forth with Seth at QSD and can't get ahold of anyone at Innovative to help me out with this question.
I'm trying to figure out which a/c compressor is best suited to retain a/c on an h2b swap in my EK civic.
From my understanding, the B/D/H compressors all have the same bolt pattern, and the D-series has the smallest compressor and would theoretically be the best.
Also, I can't get anything back from innovative on this: http://www.innovativemounts.com/Prod...ductCode=50080
Looking at a Prelude that was at Mainstream Performance, the Prelude used a serpentine belt for the alternator and A/C compressor. (NOT MY PICTURE)
Edit: I suppose worst case scenario I can just have the guy doing the swap cut/weld a notch in the frame rail to allow for clearance. EK's already have pretty good clearance as it is with minimal frame massaging. I can remember reading a few times where users didn't have to bang the frame rail at all thanks to whichever B-series mounts they used.
My beacon of hope is this thread in which this guy says innovative really helped him out in making the A/C work with his particular h2b kit:
https://honda-tech.com/forums/hybrid-engine-swaps-18/h2b-ek-hatch-possible-c-2437479/
There's also this: http://www.innovativemounts.com/Prod...ductCode=50080
Alternator/compressor belt: http://www.autopartsnetwork.com/cata...ude_year:1997_
Old 01-27-2012, 07:40 AM
Ek Forever y0!
Default Re: Which A/C Compressor for H2B q/ QSD kit
Finally got ahold of Tim at Innovative and he says:
96-00 EK Civic H22 AC Bracket
Allows me to bolt on the D-series compressor which fits and works with the OEM d-series a/c lines.
Thanks all!! I hope this information is useful to anyone else looking to retain A/C on their 96-00 H2B swap.
Old 01-27-2012, 07:45 AM
The Grumpiest
grumblemarc's Avatar
Subscribed!!!
Old 02-03-2012, 07:08 AM
kyosoeg6's Avatar
Will that bracket onky work for an ek ? Im really tinkering wirh the idea of going back to a b series motor cause i need ac in my car
Old 02-03-2012, 09:46 AM
Ek Forever y0!
Tim at innovative says the kit only works for 96-00 civics using a d-series A/C compressor on an h22 engine.
Old 02-03-2012, 09:53 AM
kyosoeg6's Avatar
sad day...
Old 02-09-2012, 07:23 PM
kyosoeg6's Avatar
I called innovative and the lady on the phone said it only works with a 96 and up compressor.
The only differences i could find was the location of the ac lines of a 92-95 compressor and the 96-00 compressor
Old 02-10-2012, 01:53 AM
Ek Forever y0!
I suppose it could work with an EG if you used the 96+ compressor. Worth a shot perhaps.
Old 04-02-2012, 04:30 AM
dewey_civic's Avatar
Are you using a full size radiator? Or just a half core and still using the stick ac components?
JD123
08-12-2018 08:45 AM
swifttib
07-12-2007 07:29 AM
ek4life
11
08-03-2006 08:28 AM
Quick Reply: Which A/C Compressor for H2B q/ QSD kit
