EK with GSR swap. I need heat.
I have a 96 civic with GSR swap. I want to get my heat working again.
What hoses do i need. One of my stock EK hoses but one doesnt. Is this
normal. Please help.
Technical Hero
Re: EK with GSR swap. I need heat.
You need more detail into your problem. Why isn't your heat working? Do you have a heater core and heater hoses? Is the car not reaching operating temperature?
"One of my stock EK hoses but one doesn't", Huh?
Just have a hose fitting problem. One hose fit on the heater control valve. But the other
hose will not fit properly. It has a server kink in it and it is leaking. Any one know the
solution?
solution?
All my old EK hardware is there. I guess what im trying to ask is that with the gsr swap what hoses must i change to get the correct fitting?
heres the hose PN from the firewall to the metal tube under the gsr manifold..
79725-ST7-000 HOSE, WATER OUTLET
Akai Star
04-06-2010 09:05 AM
