JDM H22A w/LSD trans in EK Hatch Axle Question
Old 02-28-2012, 05:41 AM
Lockner13's Avatar
Default JDM H22A w/LSD trans in EK Hatch Axle Question
Like the title says, I'm in bad need of some info for LSD axles. I am completing an H22A swap in my EK Hatch and am down to the axles, I have read and searched and read some more and cant find an answer. I have an M2B4 LSD trans and axles w/half-shaft and I'm trying to build some axles to work in the car. Now I have read everything about the 89 integra drivers side with the lsd axle cup and a 90-93 integra passenger side axle, but I'm having a little problem. The JDM LSD axle cups use the bearings that have square steel pieces made onto the back of them but the 89 and 90 axles don't so I took the yoke and bearings off the end of the prelude shaft and installed on the 90 integra shaft for the passenger side and it seemed to work perfect, but when I tried the same on the driver side shaft, the splines on the new axle shaft were bigger and it keeps the yoke from going on. I can install the LSD cup onto the standard round bearings that come on the 89 shaft and it fits together, but there is a tiny amount of play in there. Please HELP!!! I know someone else has ran into this issue before.
Thanks in advance!
Old 02-28-2012, 06:57 AM
cvcrcr99's Avatar
Default Re: JDM H22A w/LSD trans in EK Hatch Axle Question
I have Hasport swap axles sitting in my garage for a Civic with a H22 swap. LMK if you are interested.
Old 02-29-2012, 12:19 AM
EuroR808's Avatar
^x2 had these axles and they handle
Old 02-29-2012, 06:57 PM
hondasdohc's Avatar
My setup uses 93 integra axles and an accord midshaft because the prelude midshaft will always make the binding issue no matter what you do unless you buy the 300 dollar axles which if you dont have the money for get the accord midshaft and 93 integra axles no swapping inners or outers.
speedKILLS
04-17-2012 06:06 AM
AFAccord
Transmission & Drivetrain
01-29-2009 04:27 PM
wtsexton
03-14-2004 02:04 AM
CanuckCRX
08-13-2003 08:11 PM
Dgr8wun
07-30-2003 11:38 PM
Quick Reply: JDM H22A w/LSD trans in EK Hatch Axle Question
