eg hatch with lsd h22 swap
I got a 92 eg hatch. It has a Jdm h22a with lsd swap. The seal has innovative mounts. My passenger axle boots were busted. And I need to replace the axle. I have tried building one with a prelude inner and 92 teg outer joint and shaft. Bit I realized the inner prelude shaft was out of a 92Honda prelude with automatic trans and it shook bad just barely driving it out the driveway. So I took all that apart and tries using the 92 teg axle after I put it back together in the car it did the same thing just not as bad. I am lost on what to do and I need some help figuring out what I need to do from you h-t guys.
Re: eg hatch with lsd h22 swap
I read through alot of the post on the eg h22 thread and it seems like I have tried it. Do I need the under 92-96a prelude joint out if a manual car instead of the one I got out of a auto trans car. Also with that inner joint which shaft do I need the 90-93 teg or 88-89I shaft
If you har a h22 swap . Don't matter what tranny you using . You have to us 91-93 accord inter- shaft and 93 integra gsr otter axle. And you should be good to go.
Intevic so I have to use the inner joint or cuppling out of a 91-93 Honda accord and the shaft and outer joint and shaft from a 91-93 teg. Is this right.??? That's on the passenger side right.
Use the accord intermediate shaft and use 93 integra driver side axle and a 94 integra passenger axle no need to swap out the inner joints. I'm using this setup right now and it works perfect.
