H2B flywheel.
Old Nov 24, 2011 | 10:01 AM
abs0Lut's Avatar
Default H2B flywheel.
Hey I have been searching but can't really find a definitive answer. Do I use a B series or H series flywheel when going h2b? Also, any experiences with different flywheels and clutch set ups? Thanks in advance.
Old Nov 24, 2011 | 10:03 AM
Golding.racing's Avatar
Default Re: H2B flywheel.
from what i've read it depends on what kit you use. qsd = b series clutch.
Old Nov 24, 2011 | 10:09 AM
abs0Lut's Avatar
Ok I am going to go with the QSD kit, so B series flywheel too?
Old Nov 24, 2011 | 10:32 AM
2fast4u831's Avatar
I'm really 2slow
yes
Old Nov 24, 2011 | 07:53 PM
JustOneOrTwoPosts's Avatar
QSD uses a spacer for the B-series flywheel. Evolution uses their own custom made flywheel. Both uses B-series clutches.
Old Nov 25, 2011 | 09:16 AM
Libertariat's Avatar
Ek Forever y0!
100%
With the QSD kit he only difference with h2b is the engine and the kit. Everything else is literally the same as a b-series swap. Axles, clutch, etc.
The stock h22 header either has to be modified or you need to buy one of those good cheap replica h2b headers for ~$350-500.
Old Nov 25, 2011 | 12:33 PM
abs0Lut's Avatar
Understood, planning on the HighEnd Tri-Y H2B header(logic motorsports).
Old Nov 26, 2011 | 11:09 AM
Ek Forever y0!
It really is the best header for the buck:
http://vimeo.com/30353942
S2Integra
Feb 9, 2016 11:07 PM
woodenchef
Transmission & Drivetrain
Jan 3, 2013 08:24 PM
jdm knight
Dec 14, 2009 10:23 AM
BrianSi91
Northeast (Sales)
23
Nov 16, 2008 04:01 PM
PrestonCRX
May 13, 2006 06:59 AM
