obd2b to obd1 dizzy harness
Lo guys.
i can get hold of an 8 pin (its a 7 wire) obd2B distributor for my obd1 powered mk2 crx, i need to run the blue wire for the rpm cluster signal as the obd2b does not have this as its ecu controlled. Is there a male spade connection on the igniter unit like there is inside the dizzy like there is on an obd1 dizzy that i can add ?
CHeers
CHeers
aser1z
05-07-2006 06:34 PM
