OBD0 to OBD1 jumper harness questions
hey guys i bought a jumper harness off ebay to help in my d16z6 swap and im having some doubts in the wiring
Heres a link to the harness i purchased
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
just wondering if anybody has used this or knows of a wiring diagram to help me out. i have all the wires hooked up according to a rywire schematic and the only issues im having is i have 2 black wires (one of which im lead to beleive runs vtec) and a red wire and a pink wire -which id like to run to the 2 extra wires off the new distributor ................any help would be uh helpful ...im in the process of contacting the manufaturer now so hopefully i can get this fired up by the weekend! -thanks in advance
Re: OBD0 to OBD1 jumper harness questions
bump before work feels like i should just order the Rywire harness n save myself the hassel -__- idk
really wish i woulda bout the rywire kit deff a must for the next swap ...anyway i just re wired most of the harness but im stuck with the injectors and the distributor ....im thinking i can run the blue/yellow and blue/green straight to the ecu i think its like pins B14 n 15? could be wrong tho. does this sound right to anyone? also i have the injectors all set up with the red and yellow wires extrended in by my ecu again i should just be able to jump into the right wires yea? just not positive on the pins i saw a guy saying to take C1 and C2 but im thinking that they need to be in A1 and A5. i searched but found mixed reviews on both so im looking just for a straight answer if anyone knows. i just want this thing running lol
alright i got everything goin just wasent getting fuel ...i installed a fuel pressure gauge n it says its getting around 40psi ... im feeling like i need a map sensor now anybody wanna 2nd that or lead me in any other direction? any help is helpful
map sensor didnt do it -__- i had my brother watch the fuel pressure gauge and he said it drops from 40 psi down to 30 when im cranking
which wires do you have left and where do they connect to the ECU?
pin definitions --> b18c5eg.com/obd1.jpg
i got all the wires in and pluged in and right...i believe but now im not getting fuel i guess. i have a fuel pressure sensor right off the filter an says im getting 40 psi i just had my brother watch it while i was cranking tho an he says it drops to about 30 but only while cranking. im thinking thats normal from the power drain while cranking tho. i might have the tps n map sensors switched around tho so ima mess with those now i have to switch the outside wires on the tps for the mpfi swap yes?? idk i took a break from it n am coming back to it to start playing with some stuff again
