F22 in eg hatch plz help
first time H/F swap and i was wondering if someone can help me out with a problem i am having i just dropped a 90-93 f22 motor with a 95 f23 trans with f23 t bracket and 90-93 accord intermediate shaft but the motor seats a little bit crooked i cant mount the t bracket to the rear motor mount do i have to change the driver side upper bracket thats near the cam gear and if so witch one do i need...OH AND IS IT TRUE YOU CAN I USE 90-93 INTEGRA AXLES??? FOR THIS SWAP???
Re: F22 in eg hatch plz help
loosen up the cam gear side mount and then bolt up the t bracket first, then bolt up the cam gear side mount depending on what mounts used i have avid mounts on mine and i used the 93 accord intermediate shaft with integra axles that work so perfect but I used 94 integra passenger side and DA integra drivers side. did you have to cut the tranny side mount? if you did then yes you can use this axle setup.
Down Shift Motoring
10
03-06-2006 07:33 AM
theturbocivic
11-22-2002 05:26 PM
