H2b race car q's. min required
hi, i'm planning my next race car project and have a question,
i'm going to be building a complete rolling spaceframe chassis for my f20b, in my current car i run a h series gearbox but have trouble shifting from 2nd to 3rd, so was thinking about using a b series gearbox, this would help with both @wheel power and aftermarket support.
as i'll be making my own wishbones etc what is the bare essentials that i need to do this, i know i'd need a h2b adapter plate to mount box, can i use prelude axles or do i need to run b series shafts and hubs? can i make a shaft using "b" inners and "h" outers to use lude hubs?
sorry for all the q's but i'm a little unsure on this.
Thanks Adam
Thanks Adam
Re: H2b race car q's. min required
just been through it all mate. from what i can gather i just need a qsd adapter plate and flywheel spacer. (if i can buy them without rest of kit) then if i buy the hubs, axles and gearbox from say a dc2 itr.
are all the inner & outer axle sizes / splines the same on any b series?
i wont be running any ancillaries from engine and will fab up motor mounts to suit chassis.
are all b series boxes rod change instead of cable?
Go Tigers!
You will hear others refer to these hubs as "36mm", but they are not 36mm. The size of the axle nut is 36mm. I am assuming that these share the spline count of the accord, but I haven't tested this to confirm.
thanks for your input mate.
hondatech8798
10-16-2012 01:31 PM
USDM 4G VTEC
15
04-15-2003 05:54 AM
