CEL
Old Dec 14, 2011 | 08:00 AM
playlife's Avatar
Default CEL
im having a broken knock sensor, but the CEL didnt throw any code...anybody know why?
please help..
Old Dec 14, 2011 | 09:45 AM
cdaiscool's Avatar
Default Re: CEL
Does your CEL light come on when you turn the key to 'on' initially? If not, your bulb's probably blown.
Old Dec 14, 2011 | 09:51 AM
Dc4LsTeG's Avatar
EK9
Default Re: CEL
Stock or chipped ecu?and like mentioned above does your cel come on when you turn the key?
Dc4LsTeG's Avatar
EK9
Default Re: CEL
Year and make of car would help along with what engine you have
Old Dec 14, 2011 | 05:03 PM
playlife's Avatar
Default Re: CEL
Yes, the CEL come on when i turn the key on, and go off after 2-3sec.
currently using P13 MINES ecu. my car is 92-95 civic.
Old Dec 15, 2011 | 02:02 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: CEL
Program probably has knock disabled
Old Dec 15, 2011 | 08:04 PM
playlife's Avatar
Default Re: CEL
do you mean that my MINES ecu doesn't need the knock sensor?
Old Dec 15, 2011 | 08:15 PM
Dc4LsTeG's Avatar
EK9
Default Re: CEL
Yes
Old Dec 16, 2011 | 08:22 AM
playlife's Avatar
Default Re: CEL
ok thanks for the info......but something strange happen today, i tried to unplug some socket like MAP,TPS, vtec solenoid and fan switch the CEL also didnt throw any code at all.........later i tried off the ignition. with unplug some sensor socket, i turn ON the key CEL light up 2-3sec and go off, the CEL again didnt throw any code.
rrmorseb18c
Jun 13, 2005 04:53 AM
dirtyfingers
Sep 4, 2004 05:41 PM
PokeyD16Z
Jun 6, 2004 06:08 PM
92civeg
Dec 21, 2003 03:28 PM
J_SpeC_EK
Jan 8, 2003 08:49 AM
