innovativemounts
Old Feb 1, 2012 | 07:44 AM
playlife's Avatar
Default innovativemounts
is anyone here is using this setup innovative mount with innovative axles in civic eg with h22 swap.........
does this setup will clear the axles binding issue?
does the gearbox side mount will make the motor unlevel when tighten completely?
Old Feb 2, 2012 | 07:36 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: innovativemounts
The only surefire way to fix the axle binding issue is to buy a QSD H2B kit.
I'm guessing you probably could have about 1/2 purchased one after spending money on innovative axles.
Old Feb 2, 2012 | 08:47 AM
cvcrcr99's Avatar
Do you have the steel or billet Innovative mounts? I had the steel kit and I couldn't even move the car (hasport axles) since the binding was so bad. I swapped out the mounts for Hasport (billets of course) and the problem is basically gone. I am only noticing slight binding on accelaration between 20-30 mph. I have also been talking to Chris at Hasport about the issue too. I would imagine that I shouldn't have any problems with Hasport mounts and axles.
Old Feb 4, 2012 | 08:22 PM
playlife's Avatar
im planning to order the IM billet mount and axles but before ordering i need to know with using that combination will clear the binding issue or not....i cant go back to H2B setup because i already cut the original trans mount and the shifter place...spent alot of $$$ already and really hoping to settle this axles binding issue with no more headache.
yup ..everyone that doin this h22a swap was imagine should be no binding issue even slightly if we do use the same combination ( hasport mount with hasport axles or IM mount with IM axles) because they count any angle before they design the axles and mount....
abs0Lut
Oct 20, 2011 06:54 AM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
Magnaflow
Aug 15, 2003 07:25 AM
Charlie Moua
Apr 10, 2002 04:02 PM
