Bolt size for back of head to attach chain to
Old Sep 10, 2011 | 11:31 AM
PYITR01's Avatar
Default Bolt size for back of head to attach chain to
B Series- planning on dropping my engine in soon, I want to know what size bolt fit in back of the head thread to attach a chain to thanks.
Old Sep 12, 2011 | 08:04 AM
hush22's Avatar
Default Re: Bolt size for back of head to attach chain to
??? tough to answer but I like I have an idea what you are talking about. if Im correct it is a 10mm x 1.25
Old Sep 14, 2011 | 05:30 PM
dem0nk1d's Avatar
and if the bolt strips out under the massive weight.... then what??? damage the motor from the fall, damage your car.... no bueno...
the best way to remove the engine is from the bottom of the car, or use a heavy tow strap and wrap around stock mounts.
Old Sep 15, 2011 | 03:42 PM
ihaterust's Avatar
^lol this guy has no idea what hes talking about.
any 14mm head bolt from any other spot on the motor will work. think power sterring bolts. i have swapped over 300 hondas and ive been doing it for 15 years. you can also tie onto the alternator bracket, power steering bracket or mount bracket. the tranny has a loop bracket bolted to it.
the best thing to use is a seatbelt.
Old Sep 15, 2011 | 05:55 PM
dem0nk1d's Avatar
Well lets just say **** has happened in the past. If anything can go bad i've seen it. I've always dropped from the bottom. Been working on honda's from 96.
Old Sep 17, 2011 | 09:35 AM
PYITR01's Avatar
thanks guys I just used one from the power steering bracket to bolt to back of the head. Motor is inl
Slacker93eg
Jul 28, 2012 02:23 PM
codenamezero
Welding / Fabrication
13
Feb 7, 2012 01:35 PM
dbailey
13
Jan 20, 2010 12:25 PM
DC2 Mang
May 4, 2006 07:29 PM
