H2B...I NEED HELP!!
Old Dec 24, 2011 | 12:09 AM
turbo90a's Avatar
Default H2B...I NEED HELP!!
Hey was up HT i need HELP!.. i just got my H2B coupe started but its not running right it starts right up but when i drive it it jerks like its not getting fuel? i checked everything i got fuel i got spark what can it be..
wel this is what i have done to it.. i put a AEM fuel regulator, welbro 255 fuel pump, NGK spark plugs, i also took out the butterfly from the intake mani.. here is a quick video of the car ..
http://youtu.be/qMTcW888BW8
Old Dec 24, 2011 | 01:04 AM
flatblack-h22's Avatar
Default Re: H2B...I NEED HELP!!
what injectors
Old Dec 24, 2011 | 01:47 AM
turbo90a's Avatar
Originally Posted by flatblack-h22
what injectors
Stock h22 injectors
Old Dec 24, 2011 | 01:50 AM
First.EG's Avatar
did u wire in the resistor box?
Old Dec 24, 2011 | 01:53 AM
turbo90a's Avatar
No i havent i wasnt sure if i needed to install it
Old Dec 24, 2011 | 05:45 AM
2fast4u831's Avatar
I'm really 2slow
yes, you need to install it. Do that and make sure all 4 injectors work.
Old Dec 24, 2011 | 07:41 AM
H2b-eghatch's Avatar
if your injectors are peak n hold. which are obd1. tps too mayb
Old Dec 25, 2011 | 06:10 PM
turbo90a's Avatar
ok ill wire it up once i get time.. n ill let u know if it runs better thanks...
Old Dec 25, 2011 | 06:11 PM
turbo90a's Avatar
i just got a brand new TPS so i know that cant be it
Old Dec 25, 2011 | 08:38 PM
SL0WEGG's Avatar
if you're running stock h22 injectors. You NEED to run a resistor box.
Old Dec 25, 2011 | 09:04 PM
turbo90a's Avatar
thats wat everyone was saying so when i get time im going to install it..
Old Dec 25, 2011 | 09:06 PM
famous323's Avatar
if you dont mind me asking what kit did you use? qsd?
Old Dec 25, 2011 | 09:44 PM
hondasdohc's Avatar
Dude sounds like one of your injectors are not working like it's misfiring check the spark coming out the spark plug wires with a screw driver. If it's not that than if the motor is obd1 jdm h22a it needs the resistor box if its a h22a4 than no resistor box needed but only if you have the 290cc injectors. If it's not that than check your injector plugs. It looks like it bogs out when you give it gas.
Old Dec 26, 2011 | 03:03 PM
turbo90a's Avatar
i have no kit...
Old Dec 26, 2011 | 03:05 PM
turbo90a's Avatar
i know its not the spark bec we already check that. n yea its a obd1 jdm h22a.. n thats what it does bogs when i give it gas...
rebel1988us
37
Nov 26, 2012 08:54 AM
CRXWOLSKI
17
Jan 10, 2008 03:11 PM
jrs2ksi
Dec 9, 2006 04:48 PM
Project_DX
Oct 17, 2006 09:32 AM
95strfytr
Apr 27, 2005 10:32 AM
