Hybrids with HASport mounts...
Old Jan 18, 2004 | 04:26 AM
Blazin Si's Avatar
Loved
Community Favorite
Default Hybrids with HASport mounts...
**for those of you using HASport mounts with B series engines in 5th gen civic's**
do the these mounts lower the engine height when used in 5th gens? when i swapped my B18 into my civic, i put play-doh on the valve cover to see if the hood would have enough clearance to close and i had about a half inch of room.
my car is lowered and i have a JDM 4-1 header that hangs pretty low so sometimes it scrapes. i'm affraid that if i use HASport mounts it may make this problem even worse, if it does in fact lower the engine height.
Old Jan 19, 2004 | 06:56 AM
locash's Avatar
Default Re: Hybrids with HASport mounts... (Blazin Si)
The hasport B/D series kits for the EG/DC do not lower the engine at all, they leave it at stock height, or possibly a hair higher since they don't sag like the OEM mounts..
You'll be fine..
-joe
Old Jan 20, 2004 | 02:08 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: Hybrids with HASport mounts... (locash)
thanks man, i appreciate the reply.
rice a roni
Sep 19, 2017 05:21 AM
sr20paisa
Welding / Fabrication
Jan 20, 2014 05:06 PM
92egboost
Jul 18, 2008 07:02 AM
slow4thgen
Mar 5, 2003 08:17 AM
