Searched! D15B7= Bolt in/plug n play in an OBD1 CRX?
1 Post
Here's the deal, I can get a D15B7 for dirt cheap!
One of my CRX DX's has no compression, and I'm in the middle of wiring it for OBD1(future home of a B17). Can I just drop in the D15B7, in the meantime?
Are motor mounts the same?
OBD1 ECU and wiring just plug and play?
Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (4crx4me)
Simply switch the driver's side bracket and mount on the D15B7 to the stock CRX bracket and mount and it'll bolt right in. Of course you'll need to reuse the CRX's cable tranny with upper and rear mounts. If you complete the OBD1 wiring, it will make the motor basically plug and play. When you go to put the B17 in, you'll only need to wire up the extra sensors like the VTEC solenoid, VTEC pressure switch, Knock, etc.
1 Post
Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (Shadow Templar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow Templar »</TD></TR><TR><TD CLASS="quote">are u switching the head??? D15B7s arent vtec naturally i thought</TD></TR></TABLE>
I know it's not VTEC, don't need it, yet. I just need an engine to get the car driveable, so my nieghbors don't lynch me. LOL
PS: I'm only paying $100.00 for it.
Aint nothin wrong with D15B7, i have one, and i really like it. don t bother makin it a vtec tho, a cam change would do more for it. vtec ain t everything, speed is speed. obdi eh? cool ****. the only weird thing is it has a solid crank gear
Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (tgreaves)
Z6 with a Y8 gasket should drop about a second of ur et time, according to another HT memeber (bauleycivic) if u read his ****, ull get a great idea on how to do it.
94b16teg
02-22-2007 07:00 PM
