B16 AC bracket and alternator question
Old Jan 14, 2004 | 12:53 PM
-Justin-'s Avatar
Default B16 AC bracket and alternator question
Hey guys. Ok here is my thing. I have a 1st gen b16 motor that i have been building for a while now. I have not gotten a ac, ac bracket, alternator, or alternator bracket for it yet. My question is obviously, what will work for this. The engine is going into a 1993 honda civic dx. Also I have an unorthodox crank pulley, do any of yall know which pulleys to buy in order to work correctly?
TIA
Old Jan 14, 2004 | 04:14 PM
Brewer's Avatar
Default Re: B16 AC bracket and alternator question (B16EH2)
Bump for j00
Old Jan 14, 2004 | 05:42 PM
-Justin-'s Avatar
bump it on up
Old Jan 14, 2004 | 06:03 PM
VTECVillain's Avatar
You'll need a Del Sol VTEC A/C bracket to retain A/C while using the stock D series compressor. Any B series alternator bracket will work. For the alternator, get an OBD0 or OBD1 B series if you want plug and play with an OBD1 harness.
As for the underdrive racing pulleys, I don't recommend them and would never run them if they were free, but that's me. If you want a nice pulley get the JDM CTR 1 belt crank pulley but then you can't have A/C or PS.
Old Jan 14, 2004 | 08:03 PM
-Justin-'s Avatar
thanks villain. I heard there was different output with certain alternators, u know anything about that? I already have a unorthodox underdrive crank pulley on there, so a lil late on that, haha. U know the proper belts to use with ac and alternator? thanks alot guys
Old Jan 15, 2004 | 04:35 PM
doublejz's Avatar
Default Re: (B16EH2)
i have a 70 amp B series alternator. if ya need it let me know and give me an offer
Old Jan 15, 2004 | 04:37 PM
-Justin-'s Avatar
Default Re: (doublejz)
are there any differences in the amp output of the alternators?
Old Jan 15, 2004 | 06:08 PM
doublejz's Avatar
yea, i just bought a 90 amp one for an integra b/c of my stereo, my stock one was suppose to be around 68 but I got it tested and it was 72 amps, so depending on the vechile the alternator varies on amps
Old Jan 15, 2004 | 06:09 PM
-Justin-'s Avatar
hmmm. was the 90 amp for any model integra?
Old Jan 16, 2004 | 08:40 PM
-Justin-'s Avatar
hey, my friend told me there was also a mount of some sort that attached to the ac bracket, what the hell is he talkin about?
Old Jan 17, 2004 | 04:02 AM
That would be the lower driver's side dampening mount. EF and DA doesn't have it but the EG, EK and DC do. It's basically a shaft that threads into the A/C bracket then you have the rubber mount on the end that bolts up under the frame rail.
Old Jan 17, 2004 | 07:04 AM
-Justin-'s Avatar
cool man, is it necessary. or will i be fine without it and just get it later
Old Jan 17, 2004 | 07:30 AM
Brewer's Avatar
You will need to have that mount
Old Jan 17, 2004 | 07:33 AM
-Justin-'s Avatar
ok that's cool. but if i need that mount. how can all the 4th gen civc's do the swap with out it?
Old Jan 17, 2004 | 12:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EH2 &raquo;</TD></TR><TR><TD CLASS="quote">ok that's cool. but if i need that mount. how can all the 4th gen civc's do the swap with out it?</TD></TR></TABLE>
Because the EF's and DA's have a different type of mounting setup, hence the need for an aftermarket mount kit to fit a B motor in the EF. The EF's and DA's don't have front lower tranny and A/C dampening mounts that bolt under the frame rails. Instead they have a single front tranny mount in the middle that bolts to the front cross member.
Old Jan 17, 2004 | 01:44 PM
-Justin-'s Avatar
ok cool, can i use the stock d-series ac mount with the del sol vtec bracket? also i have the rear engine bracket but i dont have a rear mount, could i use the stock d-series mount with that bracket as well?
Old Jan 17, 2004 | 06:42 PM
-Justin-'s Avatar
bump
Old Jan 18, 2004 | 05:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EH2 &raquo;</TD></TR><TR><TD CLASS="quote">ok cool, can i use the stock d-series ac mount with the del sol vtec bracket? also i have the rear engine bracket but i dont have a rear mount, could i use the stock d-series mount with that bracket as well?
You can use the stock Civic rubber mount on the Del Sol VTEC A/C bracket. For the rear mount, you can use the stock rubber mount as well, it's the rear bracket that needs to be an Integra one.
Old Jan 18, 2004 | 05:52 AM
-Justin-'s Avatar
awesome, thanks for all the info man.
bradabu
Sep 2, 2011 10:16 AM
Revolution2zz
Jul 27, 2006 05:42 PM
pkgwjai082
Apr 24, 2006 05:43 AM
marc-111
Aug 22, 2005 08:07 AM
