ALL INFO NEEDED!!!!
Old Jan 11, 2004 | 04:40 PM
C M S's Avatar
Default ALL INFO NEEDED!!!!
I am about to sell my hatch, so its time to get some info on a good shell for my H22 project. I want to use a 94 teg LS. But I also am thinking of buying another hatch. I think there is maybe 200-300 pounds difference in weight, but the the look of the teg is a beautiful thing. what do you think fellow tuners??
Old Jan 11, 2004 | 05:00 PM
VTECVillain's Avatar
Default Re: ALL INFO NEEDED!!!! (1SICJDM)
Majority rules... EG hatch, preferably a 92 VX.
Old Jan 11, 2004 | 05:08 PM
Turbogixxer's Avatar
Default Re: ALL INFO NEEDED!!!! (VTECVillain)
There is no perfect trim. Some trims have options that you may want, some do not. The lightest trims are cx/vx. followed by dx, then the pig SI. Si has all the cool things, like sunroof, rear discs, etc. But it weights a lot more.
When I go looking for a hatch, I first check to see if the frame it straight. It will be hard to do a H22a swap with a bent frame. I would not care about the miles, cause you are going to do a motor swap.
https://honda-tech.com/zerothread?id=150315
hope that helps.
Old Jan 11, 2004 | 06:47 PM
C M S's Avatar
Whats the diff in weight between the 2. I have an opportunity to buy a 94 teg ls for only 2k, not many hatchs around here!
Old Jan 12, 2004 | 01:27 PM
MrParks's Avatar
integ all the way hatches are so played yesterdays look i think but i still own one
dditmars
Mar 24, 2010 08:17 AM
importdays
Aug 23, 2005 08:41 PM
BIntegra99
Oct 9, 2003 06:32 PM
Do_Ster
57
Jul 7, 2003 03:43 PM
