***HELP ASAP**** PROBLEMS WITH LS SWAP
****MORE PROBLEMS****
OK... The hose problems have been figured out.... the ground problem has been figured out... but still no spark
Ok, today we dropped a 95' b18b into a 92 honda civic h/b; so it's suppose to be the easiest drop-in ever right? well i am having a bit of a problem;
***problem 1 ***- Motor cranks over, but no spark... power is getting to the distributer but theres no spark, new wires, plugs, cap, and rotor have been put on...
***problem 2 ***- I am using the integra half shaft but the drivers side is way too long, so long it does come close to fitting...
and this is just a question... does the Ls (obd1) have 2 map sensors???
HELP HELP i need my car to start running again! thanks!
Modified by PrOjEcTpImPcIvIc at 4:23 AM 1/19/2004
Re: ***HELP ASAP**** PROBLEMS WITH LS SWAP (PrOjEcTpImPcIvIc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcTpImPcIvIc »</TD></TR><TR><TD CLASS="quote">***problem 1 ***- there are 3 wire harness plugs that "don't go anywhere" there is absolutely no where to hook them up?
!</TD></TR></TABLE>
Integras have ABS, you hatch does not. You will have extra plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcTpImPcIvIc »</TD></TR><TR><TD CLASS="quote">***problem 2 ***- there is a bunch of hoses that we had to cap off around the intake manifold(Skunk 2)/throttle body area, how many are there suppose to be left over...!</TD></TR></TABLE>
oh geez, on the top of my head. You have two hoses going to the fast idle, two going to the IACV, and you have two hoses going from the block to the coolant tube on the back of the block. All of them should be connected.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcTpImPcIvIc »</TD></TR><TR><TD CLASS="quote">Now a new problem***problem 3 *** Now the motor will crank over but it's not getting any spark, we put on new cap, rotor, wires and plugs but still no spark...</TD></TR></TABLE>
Check all your grounds (aka thermostat ground, trans ground, and valve cover). Check to see if you are getting power to the coil.
!</TD></TR></TABLE>
Re: ***HELP ASAP**** PROBLEMS WITH LS SWAP (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">The 92 dx's have vtec wired up already so thats 2 conectors but the other I'm not sure of. What mounts did you use to drop the ls in?</TD></TR></TABLE>
You have correct, all 92 civic are already wired for Vtec (from the ECU to the shock tower), But they are already on a connector so that would not be the extra connectors. You would use 94-01 integra rear trans bracket and two side mounts (a/c, and trans) from a 94-01 integra and you can reuse the other civic mounts.
I feel your pain, went through the same confussion. Don't worry about the plugs....like all have siad, there are some that the hatch doesnt have. As for the other prob, grounds are prob. not happening.
***problem 1 ***- Motor cranks over, but no spark... power is getting to the distributer but theres no spark, new wires, plugs, cap, and rotor have been put on..</TD></TR></TABLE>
Ok, you have power to the coil? you check your ingitor?
***problem 2 ***- I am using the integra half shaft but the drivers side is way too long, so long it does come close to fitting...</TD></TR></TABLE>
What axles you using? you make sure the axle/half shaft is all the way in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcTpImPcIvIc »</TD></TR><TR><TD CLASS="quote">and this is just a question... does the Ls (obd1) have 2 map sensors???</TD></TR></TABLE>
Nope, only one. It is on the throttle body.
