P28 hondata in 1992 eg with H22 questions.
1 Post
Currently i am running a chipped p13 ecu in my 1992 dx h22 hatch. I have the chance to pick up a hondata p28. My question is how many people run this in their h22 eg? What do you do about the IAB's? I know people say remove them, but i noticed a big difference between having my iabs hooked up and not hooked up when i first did the engine swap.
So, if you could just post your experience with it if you have it and any recommendations that would be great.
Thanks.
Thanks.
Re: P28 hondata in 1992 eg with H22 questions. (DIY_Racing)
Del, hit me up.... I ran the Hondata P28 on our (old) H22 EK hatchback and you know this . If you pick it up, I have a program for you.
Well when you run the p28 it does not control the iabs so there is no point to have them in there
Re: P28 hondata in 1992 eg with H22 questions. (DxTrix)
if you run a setup like this you can run the IAB with what ever ECU. But you will need an RPM switch or run of the 12+v from VTEC.
Re: P28 hondata in 1992 eg with H22 questions. (fastwanabe)
Gotta question about this. What part of vtec do you splice this wire into? Vtec pressure switch? Or Vtec solnoid?
Also, can someone explain how you can get around this? Completely do away with IAB all together? How?
Re: P28 hondata in 1992 eg with H22 questions. (00 FBP ItR)
As you all should know the intake manifold can be taken apart into many pieces. One such peice is the plenium which has an upper piece, the IABs, then the lower piece that attaches to the actual manifold runners. By simply unscrewed 4 bolt/nut combinations on the top of the plenium you can life it off and take off the IAB plate all together then just reassemble..
My recommendations for those using the p28 ECU are to either get a chip that controls that function which are available now, or just to run a vacumn line to the solenoid on the IAB to simulate them opening and closing during the RPM band. Or lastly you can hook up a switch to it..
Re: P28 hondata in 1992 eg with H22 questions. (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct »</TD></TR><TR><TD CLASS="quote">Gotta question about this. What part of vtec do you splice this wire into? Vtec pressure switch? Or Vtec solnoid?</TD></TR></TABLE>I sliced my 12v power source right from the vtec solenoid.
hmm...... my problem is i dont have anythig like what you have in your picture. I dont have that black sensor or whatever that thing is with the single wire connector on it. As a matter of fact, i dont even have that nipple on the intake manny that your little IAB valve is inline with.
Could hooking any of these vacuum lines incorrectly cause the motor to bog really bad? I cant seem to get any power whatsoever.
I need help!
I need help!
team2dcrx
08-08-2008 02:53 PM
