H22 tuning problems?
Old Jan 16, 2004 | 08:50 PM
tylek17's Avatar
Default H22 tuning problems?
I have a JDM H22A w/ JDM h22 ECU in my 4 door 92 honda accord. I don't think it is running at its best. Timing is advanced as best as it can be. I have a custom exhaust without a cat 2.25" piping all the way back and a warm air intake. before installing this engine i read it is a possilbe 14.5 sec car. Can anyone tell me how i can get it to that all motor Cams? I am also having trouble with the redline i thought it was supposed to be at 8200 but right now its only at 7800? dunno maybe a fuel flow problem bigger fuel pump?
Any help would be greatly appreciated.
Thanks Tyler
Old Jan 17, 2004 | 01:33 AM
fast+forward's Avatar
Default Re: H22 tuning problems? (tylek17)
the h22 redlines at about 7400rpms not 8200...
Old Jan 17, 2004 | 07:10 AM
Mikey3000's Avatar
Default Re: H22 tuning problems? (breakaway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breakaway &raquo;</TD></TR><TR><TD CLASS="quote">the h22 redlines at about 7400rpms not 8200...</TD></TR></TABLE>
yeah, and what do you mean timing is advanced the best it can be? what is it set at now? and how do you know it doesnt run 14.5's, have you run it on a track yet?
Old Jan 17, 2004 | 08:12 AM
H2nr's Avatar
Default Re: H22 tuning problems? (Mikey3000)
switch to a GSR ECU and get Hontata. With a good retune you can stop the power from falling off on the topend. Also pull the butter-fly out of the mani.
Old Jan 17, 2004 | 08:51 AM
tylek17's Avatar
Are you talking about the AIB BS I have it set to where it is always on the high end runners
It doesn't fell like a 14.5 car because my friends 300 ZX beat me on the highway on 60-90 pulls his car is only a 14.9 car
Old Jan 17, 2004 | 10:59 AM
H22CL's Avatar
what does pulling the butterflies out of the mani do?
Old Jan 17, 2004 | 11:00 AM
tylek17's Avatar
if you have a dual stage manifold i guess it would use the high rpm runners all the time
Old Jan 17, 2004 | 11:50 AM
Jason kiDD's Avatar
If you have not changed your fuel pump then i recommend that you do..
Old Jan 17, 2004 | 05:39 PM
tylek17's Avatar
humm so you think i should change fuel pumps.
Any suggestions on brands???
Old Jan 18, 2004 | 08:48 AM
Jason kiDD's Avatar
Default Re: (tylek17)
When i had my h22 in the accord when i changed to a high flow venom pump it made a load of a difference.. I dont know if they make a walbro for your gen accord as well but that is a great place to start..
You stock pump is already over 10 years old..
Old Jan 18, 2004 | 09:57 AM
poison's Avatar
What is your timing set at? Do you have an FPR?
Being a stock motor, I wouldn't have the timing advanced at all, just stock at 16°, keep the FPR at about the same, and get it tuned.
I'd recommend on the fuel pump upgrade.
As for the IAB's, keep 'em factory hooked up, but if you have issues with 'em, you might as well hook up the vacuum line from the IAB valve to the side of the IM, or just leave 'em open all the time.
HTH
Old Jan 18, 2004 | 10:57 AM
fastwanabe's Avatar
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tylek17 &raquo;</TD></TR><TR><TD CLASS="quote">before installing this engine i read it is a possilbe 14.5 sec car</TD></TR></TABLE>I have personally seen a gutted accord run 14.5 with a stock H22.
Old Jan 19, 2004 | 07:38 PM
tylek17's Avatar
i think it was retarded when i got it but now it is advanced i would change it the drive it and i adjusted it to my fastest time. sorry i am a newbie FPR? as for the fuel pump i am changing tha ASAP
Old Jan 19, 2004 | 09:48 PM
hondaZvic's Avatar
FPR = fuel pressure regulator
Old Jan 20, 2004 | 02:33 PM
tylek17's Avatar
Thanks :-)`
Old Jan 20, 2004 | 08:37 PM
hondaZvic's Avatar
np (no problem)
92civlude
Dec 11, 2008 01:18 PM
CRUCIAL909
Jun 12, 2007 06:46 PM
thing
Feb 9, 2006 06:04 PM
SpeedFreak77
May 9, 2005 07:40 PM
JdmCIVIC853
Feb 13, 2003 05:56 PM
