obd2 gsr swap into 96 civic hatch
Whats all needed for this swap. I have everything from the 97 gsr except mounts and shift linkage. Which parts are needed to mount the gsr engine and what shift linkage. As far as wiring goes, whats needed to do. Is there anything else that i may need to change to get this running correctly into the 96 hatch. Also, can i use the gsr intermediate shaft and axles with corresponding gsr tranny.
Re: obd2 gsr swap into 96 civic hatch (Sammex)
hmm u need the si rear bracket...u can modify the cam gear side bracket..or u can buy one from a 99-00 si..i just modified mine shift linkage from gsr..i'd use your stock hatch harness, label everything while its still on the old d series motor and match it up on the gsr..andf youd need an ecu..i used a conversion plug and a chipped p28..cause i wanted a chipped ecu and to be obd1.....no secondary o2 sensor
jdm as fk
12-04-2009 09:57 AM
swaplighter
05-15-2004 10:56 PM
