Axle options! Need help ASAP!!!!
OK here is my problem. I have access to 90 Teg axles, but no accord int-shaft. I have Prelude inter-shaft. My original plan was to run DSS axles w/Prelude shaft but now funds are gettin scarce on my EG hatch/H22 project. Will the prelude shaft work with the Teg axles? Please help out!!!
Re: Axle options! Need help ASAP!!!! (1SICJDM)
Yes, I have done it many times. On auto teg axles you have to use a thinner bottom clip to allow the thicker lude tripod on the shaft (i just use a top clip from the lude CV and the teg top clip for the top). You can run just the lude CV cup on the teg bearing, but I do not like it. Some axles have too much play in them for that.
I hope you understand that. If you, just tell me what you do not understand and I will explain it again.
patastinky
05-09-2005 05:43 AM
