ecu work with a usdm obd2 b18c in a 1992 ls
i did a usdm b18c1 swap into a 1992 DA i beleve i need a usdm obd1 p72 ecu to get everything to work correctly. i used the DA harness and injectors, and a obd1 vtec distributor. i had to run 10 extra wires from the extra sensors i found on the motor exe.. vtec celinoid knock sensor, dual stage im i beleve. crank pos sensor, where and how do i plug these 10 wires into the obd1 p72?
Re: ecu work with a usdm obd2 b18c in a 1992 ls (cstay)
You need the pinout chart for an OBD1 P72: OBD1 P72 Pinouts
Ekcouper
10-24-2012 06:40 AM
