tps ?
Old Jan 11, 2004 | 06:20 PM
dpine's Avatar
Default tps ?
I have a question about the tps. Will the ecu throw a code if the tps is not adjusted correctly? the reason I ask this is because I changed out my tps tonight because it was broken. We set it to .38 volts at idle reset the ecu and started the car. threw code 7 again. We packed it up for the night because it was to cold outside(10 degrees). Just wondering because the car idles fine and seams to rev up fine. thanks
Old Jan 11, 2004 | 06:29 PM
Devlins 91LS's Avatar
Default Re: tps ? (dpine)
You'll only throw a code if the tps isn't connected, check your wiring.
Old Jan 11, 2004 | 06:44 PM
VTECVillain's Avatar
Default Re: tps ? (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">You'll only throw a code if the tps isn't connected, check your wiring.</TD></TR></TABLE>
That's not true, the TPS has a fine adjustment similar to your distributor and requires a proper voltage. If you have it set off and the voltage is not within spec, it will trip the TPS cel as if it were unplugged.
Old Jan 11, 2004 | 06:56 PM
dpine's Avatar
Default Re: tps ? (VTECVillain)
say I set the idle volts to .5 and I can't get WOT volts to 4.50. Is that bad. Meaning another bad tps?
Old Jan 15, 2004 | 02:11 PM
dpine's Avatar
I there some magic trick to adjusting the tps. I am on the middle wire red/blue and I have adjusted the tps by loosining the bolts on it and moving it from left to right. Now all I get is .13 volts at idle which ever way I go (left to right). Is there a difference in adjustment with the screws on the top and bottom of the tps that hold it to the manifold? What am I doing wrong?
Old Jan 15, 2004 | 03:22 PM
Kamin's Avatar
nope
if its mis-calibrated it will give a CEL too, as vtec villian said.
Old Jan 15, 2004 | 04:20 PM
dpine's Avatar
Default Re: tps ? (Kamin)
Anyone have instructions? I have a volt meter what do I need to set to V, mV, Vdc, Vac? any help would be appreciated. thanks
andyc_0652
Nov 18, 2010 06:54 PM
Juan_Mitosis
Feb 4, 2008 04:39 PM
ludacole
Aug 13, 2005 11:59 PM
d15b7racer
Jan 16, 2005 09:43 PM
phatrick2332
Jul 22, 2004 08:44 PM
