Alternator question?
Old Jan 22, 2004 | 11:08 AM
yellowCRX6's Avatar
Default Alternator question?
i have a 94 LS motor with no distributor and no alternator. Im looking for an OBD0 distributor, and im getting an obd0 pr4. I was curious what year alternator to get. should i get the 94, cuz i think it will match the belts? or do i get one to stay with OBD0? i dont even know if that matters.....
Old Jan 22, 2004 | 12:20 PM
Katman's Avatar
Default Re: Alternator question? (yellowCRX6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowCRX6 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 LS motor with no distributor and no alternator. Im looking for an OBD0 distributor, and im getting an obd0 pr4. I was curious what year alternator to get. should i get the 94, cuz i think it will match the belts? or do i get one to stay with OBD0? i dont even know if that matters..... </TD></TR></TABLE>
your on the right track as far as the distributor & ecu goes if this motor is going into a CRX. The OBD1 LS alternator should be compatible with your CRX OBD-0 engine harness though.
Old Jan 22, 2004 | 12:30 PM
yellowCRX6's Avatar
Default Re: Alternator question? (Katman)
i was told it SHOULD WORK by some 1 else also, so im just gonna go for it.
anyone say not get the 94 alternator?
Old Jan 22, 2004 | 01:07 PM
Katman's Avatar
I say just try it, rather than wait for a unanimous decision, and if the OBD1 LS alternator doesn't work, just use a 90-91 LS alternator.
Old Jan 22, 2004 | 01:12 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">The OBD1 LS alternator should be compatible with your CRX OBD-0 engine harness though.</TD></TR></TABLE>
It does work. I did it before. You can use OBD0/1 alt. with either a obd0/1 ECU, it will work. The belt (alt) will work too.
Old Jan 23, 2004 | 06:38 AM
Flexmyrex's Avatar
i have the ecu for you pr4, $50
Old Jan 23, 2004 | 01:20 PM
yellowCRX6's Avatar
Default Re: Alternator question? (Flexmyrex)
i got the same price elsewhere... but for a little more money,im gettin a ton more ****. thanks tho!
ekhatch9
Sep 22, 2010 05:33 PM
hondahustle
Mar 30, 2007 09:54 AM
dr_latino999
Aug 31, 2006 07:32 AM
HiProfile
Jul 25, 2005 08:48 PM
