92 teg radiator fit in EG?
Re: 92 teg radiator fit in EG? (Beatkidd)
it will not fit unless u make custom brackets on the top and bottom... it can be done, its not that hard but its not going to look pretty.. hope that helps
ived seen the 92-93 integra showa radiators in an eg chassis and it does fit. top custom brackets have to be made(im sure its not difficult). good luck.
Re: 92 teg radiator fit in EG? (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote"> Buy a Del Sol dual core!</TD></TR></TABLE>
bolts right in
bolts right in
Re: 92 teg radiator fit in EG? (B18C2_sedan)
do you need one? I'm running a B18C5 with a bunch of extra **** and still the stock little EX radiator. Never had a problem overheating, temp doesn't even rise.
Re: 92 teg radiator fit in EG? (hadehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch »</TD></TR><TR><TD CLASS="quote">it will not fit unless u make custom brackets on the top and bottom... it can be done, its not that hard but its not going to look pretty.. hope that helps</TD></TR></TABLE>
Only bottom brackets need to be made. You can still use the stock "radiator support brackets" on the top, but need to have them in different 10mm holes on the core support. On the bottom, you need to make custom brackets but it's not that difficult, but pretty close to the alternator pulley on a H22 swap.
TRU_Luck
12-27-2007 02:46 PM
B18Cej1
14
09-10-2005 04:22 PM
