what parts do i need for B18 into crx?
I was curious of the parts i need for a B18B1 into a 91 crx SI. I know an OBD0 pr4 ecu, the motor, im gettin a ys-1 tranny, have a clutch a flywheel. 90 -93 integra axles and inter. shaft. Has any 1 done the swap themselves?
I was wondering what else. i think 90-93 throttle cable? , what about radiator hoses? if im missing other parts let me know what i need to get. thanks
Re: what parts do i need for B18 into crx? (yellowCRX6)
I have
a b18b motor with harness's, sensors, and manifolds
clutch and flywheel
and am getting
a tranny
pr4 obd0 ecu
obd0 dist.
90-93 teg axles and inter. shaft
mounts and linkage
90-91 ls upper and lower rad. hoses
90-93 teg rear tranny mount
i was wodnerinf if there were any other parts i need?
clutch and flywheel
and am getting
a tranny
pr4 obd0 ecu
obd0 dist.
mounts and linkage
you will also need the 90-91 Injectors also. Ohh and I think Place Racing or Hasport makes a throttle cable bracket to run the 90-93 throttle cable. You will also need the motor mounts. HAsport makes some very good motor mournts for the swap.
89Si
05-11-2003 03:37 PM
nichols
10
02-15-2003 09:44 AM
