? about jdm sir II rear disk brake conversion onto eg
B A N N E D
okay , i purchased a set of jdm sir II rear disk brakes a while back for my eg. got a few questions before i attempt the install. i know that the lca's are identical to the usdm itr so i am going to swap out the lca's and use my stock eg ones so i can use my aftermarket shocks.
what brake lines, etc. will i need to complete this swap(from which car)? also, any, dohc brake booster will work, correct? any other parts that i may need? thanks.
Re: ? about jdm sir II rear disk brake conversion onto eg (vtecb20coupe)
any brake booster will work. but a gsr would be nice for your setup.
as far as brake lines there will be a rubber line separating caliper from the rest of the line. if you dont have one get an integra 94-up. other then that the whole thing is pretty easy. enjoy and good luck
B A N N E D
Re: ? about jdm sir II rear disk brake conversion onto eg (H23vtecEG)
ok, which e brake cables do i need? if you've got the part #'s, that'll work as well.
B A N N E D
hmmm...just thought about something.
i'm not at home right now to measure, but is the wheel pattern for the jdm eg 4x100 or 4x114.3?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe »</TD></TR><TR><TD CLASS="quote">4x100 </TD></TR></TABLE>
Yea, it's 4x100, and you can get order the ebrake cables for a 92-95 Si hatch, mine were about 88 bucks for both from http://www.hondaautomotiveparts.com
Also pick up the same year/model brakelines.
the only other thing i can say is with the booster make sure you use the gsr master cylinder as well
B A N N E D
Re: ? about jdm sir II rear disk brake conversion onto eg (b18blove)
ok, will do
gsr brake booster
gsr master cylinder
eg si e-brake cables
eg si brake lines?
gsr brake booster
gsr master cylinder
eg si brake lines?
cehcivic15
05-05-2010 08:45 AM
